KING46Calais V
- Feb 27, 2018
- 764
- 508
- 93
- Location
- Sydney
- 2017 VFII Calais V 6.2L Sed
In my old VX V6 I used to take out the 2 knock sensors at bottom of the block. It would completely drain the block of coolant.@VFSV6FORME, I wouldn’t get too caught up on coolant concentration % too much.
Having said that, your process is correct.
I don’t know how much remains in the block after flushing, so first drain a correctly filled system via the radiator drain plug into a big container. Then measure the volume of fluid that comes out.
The vehicle specs should indicate the total coolant volume. What remains in the system is the total volume - drained volume.
Also the needed concentrate volume for a 50/50 mix = 1/2 total coolant volume.
The only difficulty is if the drained volume < needed concentrate volume but I don’t think that would be the case.
So, it should be ok to flush using whatever technique you want to use. Then pour into the radiator the needed concentrate volume. Finally fill up the remainder of the system with your demineralised water It won’t kill the car... after all swallowing before chewing never killed anyone I know of
Then I could shove the hose up there and give it a good flush and drain then refill.
Ahhh to be young and keen
