G
grum1971
Guest
can someone help me with a diagram or pictures of a vn series 2 cruise control fitted please:bang: :bow:
The wiring on mine, following back from the module, goes under the airbox, and over across the top of the radiator, then up the drivers side of the car and into a gromot hole, although I think my cruise control was fitted after the factory buts its definately genuine holden cruise control.grum1971 said:i cant find the wiring under the bonnet but the wiring for the brakes and the switch are both there anyone got any sugges?:bang: :ranting:
No pretty sure you have to use a separate switch, another brake light switch should work.hi i am doing this conversion and following your diagram. can you tell me if i can wire this up through my original brake light switch as i was not supplied any specific to the cruise when i bought it? Thanks Jamie
