- Apr 15, 2006
- 22,638
- 20,532
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
yep , pretty much all the diffs refered to in the OP are live axle unless it says IRS.
the VN and VS diffs are the same. the only hickup you may encounter is that the VS may have ABS. if that is the case then swapping the whole axle out is going to create hassles as the VN diff housing doesn't have the bits for the ABS. if you just put the VN gears and LSD center into your VS diff housing then it won't be a problem:thumbsup:
