I work in a place rife with acronyms but what is the DOC connector?
UPDATE: my “Auto-Remote Start” is now functioning again without doing anything further, just thought I’d try it again this afternoon and varoom she barked into life... Hmm...
Well, I’ve still got to find this damn elusive BATT+ Fuse... In the ‘dash’ behind centre console maybe (will take a look and get back on that)..?
Hey Gridlocked,
The “DOC” connector is the “Dealer Optional Connector” and, in the VF’s at least, is located behind the glovebox.
I, like a lot of others, have used it for my DASH Camera (BlackVue DR750S-1CH) due to this connector having the following:
1x Constant Earth
1x Constant Power (Battery +)
—> 15Amp(?) Fuse located ???
1x RAP or Accessory Power
—> 10Amp Fuse located in Rear (Sedan & Wagon) above Battery; RAP ACC
When I was adding an additional item (LED lighting) in my Cabin I was linking into this connector (I’d already used for my DASH Cam) and accidentally (stupidly) shorted the wires blowing the fuses.
As I said in my previous post, I’ve found and replaced the 10Amp RAP ACC fuse so that’s working good again, however, the Battery + Constant Power still isn’t?
This means my DASH Cam no longer remains powered after turning off and locking the vehicle.
I’ve since noticed that my “Auto-Remote Start” is also no longer functioning since this incident yet my “Push-Button Start” works fine?
I even hear like a little click and my indicators flash (like normal) and then nothing the engine doesn’t start?
So I’m now thinking that’s related to same fuse perhaps and really hoping someone can help.
I’ve gone through and tested “EVERY”, and I mean “EVERY”, fuse I could find in the rear of my wagon above Battery on the passenger side just back from the taillight, and, in the front under the bonnet on drivers side just back from the headlight.
Argh, why couldn’t they just put the fuses, for the wires that are literally side-by-side in the very “SAME” plug (DOC), together for foxsake..?!
Back I go now looking more... HELP!
