If that’s the case then why does just adding the OTR without a tune only result in a 4kw gain? The MAF should recognise the extra airflow coming in and fuel up accordingly even on a factory tune.
I highly suspect the video is being selective with its facts. They were in the business (not anymore according to google) of selling upgrades so they arent about to say you can get 90% of your power from just a dyno tune and not pay 500 bucks for a OTR.
the vcm OTR was 22kw gain without a tune, then more then likely gained the extra 20kw because the TM wasnt removing timing from the change in airflow it saw, if the tune was set without any TM torque reduction from factory the gains would be minimal from the tune but more from the OTR as even adding it to a stock tune can take out even more timing because it has even more torque to deal with and remove, if the limit is 200nm torque and u add more airflow it will increase the torque output so it will then have to remove even more timing to get back to the same 200nm limit,
i prob should have added once u are tuned then adding performance parts makes the bigger difference then the tune, the factory tune has limits that need to be removed to make use of any added airflow, also changing the intake then needs the MAF to be adjusted as it only suits the factory intake for fueling, the MAF dosnt tell the ecu how much air is flowing in its not a set figure, the frequency it puts out is against a table u can adjust that then tells the ecu how much airflow is going in so if u use a bigger intake diameter it will slow the airflow over the maf so it will read lower then it should so then has to be adjusted in the tune
