Dropping sump because of sludge (pic inside) [update, more pictures]
Late arrival
Geeling
VZ Exc
the Haynes book says the timing covers have to be removed to drop the sump but looking at the underside that doesn't seem right. I just spent all night getting to the valves I'd love to not have to pull apart the front of the engine as well.
I was just planning to jack the engine from the trans, not bothering with lowering the kbar. Will that work?
Benboy
Hill River, SA
2007 SVZ Wagon
Here's some further reading on the subject (see attached PDFs below) :
  • VZ Sump Removal with engine in car.pdf
  • VZ Sump Removal and Replacement.pdf
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
Weather you actually need to or not, I'd be removing the timing cover and near everything I can to clean it out properly.
DaveNZ
Auckland
VR Ute,3.8,T5
..I'd be removing the timing cover and near everything I can to clean it out properly.
+1.
but it's a slippery slope.. now you have got in that far do you do the thermostat? & if you take off the timing cover do you do the timing chains & waterpump? & if you take off the sump do you do oil pump? if i were keeping it i would, but looking at that pic i would be running from it.
all the best mate
gossie
Gold Coast.
VE International 3.6L
Bad sludge indeed.
Can you tell us how often the oil and filter were changed, and what oil was used please? I would hate mine to get like that, so I'm interested in learning.
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
My god
What the
Hell
Happened.
Philmecrackun
Lismore
VFII Calais V 6.2L 1972 Ford Galaxie Wagon 400ci
Holy mackerel, there is some sludge in there, how many km's are on the motor or has it not been serviced regularly?
kiwicon
NZ
VS V8 Manual
kids tip their chocolate dairy food in there
