Drove with out a belt!
53
2000 l67 commodore berlina
My drive belt broke & i drove for about 3 km before stopping. Ive replaced the belt but i now have a lumpy idle in park & drive. It kind of skips a beat. have i done any damage? Or is the idle problem just a coinsidance.
losh1971
North Tas
VE Series I SS Ute
Did the temp sky rocket? Might be up for head resurface and new gaskets plus bolts etc.
EYY
VS Statesman
Coolant will still circulate without the water pump (albeit slower). Thermo fans help to facilitate this. As long as it didn’t boil over and spew all the coolant out it should be fine.
Juice3
Australia
VX
3km is nothing i don't think you damaged anything but not sure why you got a bad idle
Aussie Trev
72
Queensland
2 by VX Acclaim Wagon Series II 2001 & 2002
When the belt broke it may have damaged the crank angle sensor behind the harmonic balancer.
losh1971
North Tas
VE Series I SS Ute
Yes agree with Trev, if you have wire threads caught up inside the balancer this will cause a miss, happened to me.
V6formethx
VE Commodore Auto Sedan + VE Commodore SV6 Man Ute
I'd agree with the last 2 comments. Worth checking the wires to the coil pack for damage too and also the spark plug leads as they are in the line of fire when the belt breaks. I'm pretty sure the crank sensor should also put the engine light on now I think about it, so if its not on maybe look elsewhere first.
losh1971
North Tas
VE Series I SS Ute
strands of wire around CAS can cause a miss and not throw a CEL, I know.
