Just one extra question.. what is the need for the isolator switch? Does the isolator need to be manually told when the car is off?
Thanks for the help so far.
No (sort of). On the isolater there is 4 points, Positive in, positive out, Switch/Feed In, and the earth. For the Isolator to engage the second battery that Switch/feed in needs to have 12volts. Theres a few ways to do this:
1. I run mine from the Cruise Control module (it was blank but wired in from factory to be active when ignition is "on") then I run a switch to give me the ability turn it off and on.
2. Run it fron the Alternator directly, that way it is only connected when the car is running instead of the ignition being at "on".
3. Run a 12v wire from battery to a switch, and back to solenoid and choose when you want them engaged.
If theres no 12v going to the switch/feed in then it isolates/seperates the batteries.
I THINK you can also just run a wire from the switch/feed in to the negative, which would join them constantly, which is pointless, I wouldnt bother.
