A local just done the carb conversion on his VS ute down here...your 308 manifold wont do,buy a manifold to suit VN heads,there are a few manufacturers who do manifolds,aftermarket electronic dizzy,and he changed the cam,not sure if for a bigger cam,or for the dizzy.Do it,its a lot easier to find a good VN/VR/VS 5.0 than an old 308....the last of the 308s are over 20 years old....plus if u get a VR/VS block its already clearanced for a stroker crank if you feel like letting those heads and unrestricted intake work for you....When I get another early girl she will be a carb 304....A mate has a VL,was running a VN 355 stroker,heads were cleaned up a little in the ports,unsure of cam specs,BG mighty demon carb,and was running consistent 10.6s on 15 inch slicks and a trimatic.
