EGR and Intake Manifold
MrMang3058
VIC
VY Acclaim S2
Edit: Mine is the one on the right
Okay so I have gone thru two egrs due to snapping the pipe after I realised the pipe isn't actually long enough my manifold is the series two I believe cause the thread where you attach the EGR pipe is up higher so my question is.
Is there anyway to modify the manifold or the EGR pipe to connect the two together
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Edit: Mine the one on the right
Where is the rest of it?
MrMang3058
VIC
VY Acclaim S2
The EGR is in the car was gunna swap the manifolds over but won't work cause different y piece. But I tried take the manifold off attaching it too the EGR and putting it on won't work need to be like 50mm longer
Lex
Geelong Victoria
Whats yours s1 or 2?
ephect
Donating Member
VS Acclaim V6
VZ alloytec may not be at all compatible with ecotec egr pipes.
No idea but maybe best to get a the correct manifolds or raid the wreckers for a longer one to suit the lower positioned erg.
Fu Manchu
WA.
100% not compatible with VZ
This thread needs to be moved to VY.
