Shounak
The Kicking Horse
- Apr 20, 2005
- 2,500
- 60
- 0
- Age
- 37
- Location
- Vic
- VX Executive S2 + XF Panel Van Project
I'm having a few problems with my air compressor at my place. The house is about 40 years old and I'm not sure how old the electrics are, but the fuses are the ceramic type with wire.
I have a Peerless P14, 10 AMP compressor which apparently uses up most of the 10 amps. It's a 50kg (or so) heavy belt driven thing which usually works a treat (at any house but this one).
It starts up just fine and fills up with air perfectly, until I start using the rattle gun. After I've used up enough air it begins to restart the refilling process but conks out after a few seconds. It has something called a TEFC switch, which is pushes out and it starts trying to make air again once I press that in.
But it only goes on after the compressor has conked out. After trying to turn this compressor on and off a few times for a bit of air, I'll usually end up blowing a fuse, after which I replace it with 15amp fuse wire.
I'm guessing the problem is that the compressor is drawing more power than it has available, but are there any other explanations or things that can be done?
