Add to that thermal expansion and you get a much higher CFM requirement of the exhaust than you would ever see in a bench flow test.
Just get your cocks out and compare sizes already. Enuff of this ****.
I've always been of the opinion that IF I have to get my cock out, somebody is going to have to suck it!
You either get it sucked a lot, or you don't take a piss very often.....
Your numbers seem off...
130cfm x 3.43 = 445.9 cfm at the merge, but decreasing as air temp decreases along it's length
I have a table that suggests that a 2 1/2" twin system flows about 509CFM, and a twin 2 1/4" about 408 CFM total. How To Calculate Muffler Size and Exhaust Pipe Diameter | Exhaust Videos
I used this conversion for my new design, but it's based on Engine Horsepower, rather than doing a FI flow calculation. I'm using the old rule of thumb that rear wheel HP (308 on my 6) = Engine kW. That means an estimated 400HP at the engine, and a twin 2.5" need on my six.
It also means that my current exhaust (Single 2.5") is really restrictive
On your system I'm thinking of Headers with 3" collectors, 3" ballistic cats, then a twin 2.5" from the cats back.
