madmarlon
- Nov 17, 2022
- 3
- 5
- 3
- Age
- 54
- Location
- Gold Coast
- VF Commodore UTE V6 2014
Hi,
Done a search for this fault on forum and can't find exact same problem, so hopefully someone can help.
My LFX motor seized in my VF 2014 V6 Auto UTE so decided to swap out engine as easiest path to fix.
Donor motor from wrecker had wiring loom and sensors with it.
Left original ECU in car. Left original transmission in car.
Tried to start after changeover and relays clicked but no turn over. Fuel showing super low and loads of service messages come up.
Tried to connect my Thinkcar OBD Scanner but it won't communicate with ECU. It talks to BCM and any other modules that don't require presence of ECU.
I thought perhaps ECU was shot and so I replaced it from donor car (I know that security will need removing to work but I thought I might get OBD COMM's going)
I still have no COMM's and still have same fault.
I did not swap original sensors over. If they are canbus sensors could this be the issue if they had VINs registered?? If so which ones do I swap over.
Any help will be appreciated, as it's doing my head in.
Thanks
Marlon
Thanks
Marlon
