Alcyone
- Feb 25, 2016
- 174
- 3
- 18
- Location
- Victoria
- VY 2003 V6 Ecotec
VY V6 Ecotec 360,000 km's engine is out and on the engine stand. Heads are in the shop. Was blowing coolant out spark plug 6 hole when compression test done. That's how all this came to be. Left head was getting approx 140psi on all cylinders (1, 3, 5). Cylinder 2 was about 140 too. Took right head off and cylinder 6 was full of coolant. I didn't see any cracks in the right head gasket so I took the head and gasket into the shop. There was some degradation in the factory graphite/composite right head gasket in between cylinder 4 and 6 which the chap said was the cause of the leak.
Chap also said the intake valves were recessed in on both heads and needed to be redone inc valve stem seals. Head's are fine apart from that. I told him I was at the point of just having taken the front cover off the engine and timing chain was good etc and I was about to take the camshaft out to check it...seeing as everything was already out. He said not to bother and to just leave the camshaft and crankshaft, pistons, rings etc in place. A lot of oil gunk also led me to pull apart the lifters and clean them out. Amazing how much old oil and crud those things can hold if the car doesn't get regular oil changes. Valve train is good apart from that. Cleaned out the oil sump, oil pump etc.
Anyway...so chap wants $960 for the assessment of heads, cleaning, machining, valve seat job, Permaseal full gasket kit, head bolts and valve stem seals. I'm guessing the majority of that is approx $200 per head for the valve stem job each side...bit of work involved.
My question is about the pistons and rings. Should I go that little bit further and check them or throw it all back together and then do a compression test and keep my fingers crossed? Why would he say to not do it when I'm at this point? This is the first engine I've pulled apart and it's been both enjoyable and frustrating but I've learnt a lot. I have read up on heaps of things here and other places and also studied all the parts in the manual. I'm not experienced in all of this by any means but I can't get why he would say not to check the piston rings and camshaft etc. Can't afford any more money and sure as hell don't want block issues a few hundred or thousand km's down the road.
Trying to get some advice on what to do and whether to keep going or just wait for the heads, gasket kit and whack it all back together. It's Mum's car and she does about 5,000 km's - 10,000 km's a year in it now and if it gets another 100,000 km's then she'll be jumping for joy. Is the crankshaft and bearings really involved? So far everything has been pretty cruisy and I have the time to do it so that's not an issue.
Cheers,
Matt
Cheers,
Matt
