Alcyone
- Feb 25, 2016
- 174
- 3
- 18
- Location
- Victoria
- VY 2003 V6 Ecotec
Yeah 4 weeks for heads and 2 weeks so far for block is a fair bit. He said the other day that they were flat out so I'll wait until mid week to call them back. Might just drop in with the heads and see where they're at. 45 min drive there so don't want to do it more than I have to. The first place I rang to get the work done said 3 day turn around time so I thought this place would be the same.260 celsius will be fine. That much rust scale shouldnt come out after acid bathing in my opinion I havent had an issue like that before. If the acids not got all the paint off hit it with a wire brush. Never heard of powdercoated heads thought they were always painted. Could be wrong happens occasionally
They're definitely taking their time when I had my crank polished block dipped heads dipped and faced it took three days to turn them around and get them back.
Also on your scooby doo motor are you running stock carb? If so look at going a 32/36 great little carburetor on anything that size. Wont really increase fuel usage as progressive linkage but they perform very well and easy to tune.
Yep Hitachi stock carb. I was thinking of getting a Weber 32/36 but wasn't sure if it was legal or not. Even though the engine wasn't designed for EGR, they went and drilled a hole in the intake and whacked one in the buggers. I think that means I'm stuck with emissions regulations and I can't run the Weber? Not sure. Unbelievable how many vacuum lines this engine has. If I threw a Weber in, I would have to seal a lot of the stuff up. I'm not 100% sure but from what I researched, I'm not able to do it. It's a 1991 model if that helps.
The secondary barrel in this one pretty much never kicks in. I was gonna put the metal linkage in myself for it...play with it a bit to make sure it's not opening up too early. Can kinda see it when your doing it though. Does it use much more fuel do you know?...putting the metal linkage to the secondary? I even picked up a Fuel Miser Rebuild kit, new float set, extra gaskets and even bought a spare carb with some other 2nd hand parts I picked up from another L-Series in QLD. I would much preferred to have bought a Weber for about $400 but I didn't think I was able to. I just want it to sound a little bit better (if that's possible lol) and have a little bit more if I ever want to overtake a cow or sheep on the way into town...in the past, they always had the upper hand.
