bighands
- Oct 22, 2023
- 1
- 0
- 1
- Age
- 58
- Location
- Adelaide
- Wh Caprice
Hi guys, lve just put a LS1 from 2001 statesman into 2000 Caprice. It cranks over for about sec then stop. I then swapped ECU pcm fob. Does the same cranks won't start. I've noticed that the fuse/ relay setup is different. Do l need to swap the engine loom or something else. The motor/ trans not standard and ran perfectly in the stato. Any advice would be appreciated. Cheers
