jgdogbreath
- Aug 12, 2006
- 2
- 1
- 0
- VX lumina
Hi
just in case anyone else has the same problem. Fan blower (for heater/aircon) stopped working in my Vx Lumina.
Crawl under dash passenger side, remove plug going to fan blower motor, remove plastic cover, and then remove three bolts that hold the blower motor in.
Drop the blower motor out, undo the 2 screws opposite the fan assembly and remove the motor cover. Clean out the innards (mine was covered in grunge, dust, dead bugs etc), reassemble and voila you've saved some $$$. Watch out for the springs and bushes though.
Overall, you should be able to do it in an hour or so.
Always check to see if fuse is blown first, and the resistors. And watch out for the air bag wires (don't touch!!!).
best of luck
DB
best of luck
DB
