Fault code list Vt commodore V6 not turbo or supercharge sedan
commodoredave
64
sydney
vt
Got a scan on the VT fault codes.
23 Intake air signal voltage IAT
64 left lean exhaust ( does this mean oxy sensor)
76 short term fuel trim delta high
92 no bcm response
Can anyone suggest the fixes necessary
lout
60
Langwarrin Victoria
what was current and what pending or history
clear the codes and see what comes back
what bank and rpm range for fuel trim
who did the scan and what scanner used
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
92 no bcm response
Error code 92 What the manual reads.
BlackVXGTS
Melbourne, SE
Here you go, note that you need a Tech2 (or equivalent) scan tool for most of the diagnostics:
  • DTC 23 V6 PCM - INTAKE AIR TEMPERATURE (IAT) (SIGNAL VOLTAGE HIGH).pdf
  • DTC 64 V6 PCM - LEFT HAND (LH) LEAN EXHAUST INDICATION.pdf
  • DTC 76 V6 PCM - SHORT TERM FUEL TRIM (STFT) DELTA HIGH.pdf
  • DTC 92 V6 PCM - LOW SPEED FAN - NO BCM RESPONSE.pdf
