Fault codes are gone!! my Vz holden 2004 sedan auto ..please help''..SRS bag fault after changing cluster
Lisa KNUDSEN
goodna qld
VZ HOLDEN 2004
my codes are gone.Ultra tune couldnt fix
  • Fault Codes (2).pdf
Lisa KNUDSEN
goodna qld
VZ HOLDEN 2004
bought this but I need help please
Fu Manchu
WA.
It’s because the cluster is set up to expect certain number of airbags. You may have more or less of them.
The cluster needs to be correctly set up using a Tech2 interface or high end. Also can send off to Envyous Customs here in WA who will set it up correctly. All your codes will go once the cluster is set up correctly.
Fu Manchu
WA.
If your car had two airbags, but the cluster came out of a car with 4 airbags, there’s going to be issues.
Also speedo might be out if it came from a V8 and yours is V6.
Fuel gauge can be jiggered if models are mismatched as well.
It’s quite a list.
When i had my Calais cluster installed in my V6 Crewman, Envyous Customs has quite a list of required questions that needed to be answered. I also had to provide my left nut as proof of kms which had to be matched.
It is even possible to have a custom start up logo to replace the Holden one that appears on the screen.
Fu Manchu
WA.
That device won’t perform the tasks required to set up the cluster.
It is certainly a great gadget to have when things go wrong. It will give you a much easier starting point though and save a lot of being stuffed around and being bullshitted too by workshops.
Fu Manchu
WA.
Should do.
