trctrctrc
- Nov 14, 2019
- 8
- 3
- 3
- Age
- 29
- Location
- Perth
- VF SSV Ute
Hi all,
Putting this post up to track a fault and for future reference in the hopes it helps other people who may encounter the same problem. I have a 2014 VF SSV ute (L77 6.0) that has developed a sudden stall after approximately 40 minutes of driving or running, with the message "Engine Power Reduced" on the dash cluster. The car will not start afterwards, the dash goes through the usual process of starting without attempting to turn over the engine. The only way to get it to start after this is to clear the MIL (engine) light or disconnect the battery for >30 seconds and reconnect it - starting after this is OK and will subsequently reproduce the issue after 2-5 minutes of driving.
The ECU throws the error P0601 - Internal Control Module Memory Check Sum Error, from ECU 7E0. This malfunction is reproducible after about 40 minutes of run-time, consistently. I run a series of troubleshooting steps to rule out contributing factors to this issue, main step being battery replacement as it was on its way out - a bit of info online suggests similar codes are thrown when voltage inconsistencies are experienced by the ECU.
The behaviour of the issue goes as follows:
The part number that suits my model (other models may vary) is: 12633238
Name: GM E38 or E38 Engine Control Module
Hopefully around this time next week I'll be getting the replacement ECU installed and flashed and the issue no longer occurs. Hopefully...
- Dash cluster displays "Engine Power Reduced", check engine light is lit and instantly shuts off engine - this occurs after about 40 minutes of runtime
- Transmission is thrown into neutral regardless of gear - car will simply coast to a halt
- Fuel and temp gauges are held in typical running position but the tacho and speedo read 0
- Upon attempting to restart the car, a relay click is heard, all interior electronics are turned off and won't turn back on until Start/Stop is pushed again - nothing happens with the engine
- The engine will not restart unless MIL light is cleared by OBD utility or battery is disconnected for >30 seconds
- Upon starting the car again it'll run like nothing happened and go back to 1. after about 2.5 minutes of subsequent run time
