Sik_Cordz
hey guys anyone here fitted ve hsv seats in there vl. is it just a matter of getting the ve seat to fit the vl rails or is there more to it. just looking for anyone that has done it them self's cheers
VE SS seats in a late model VK yes (very similar rails to the VL) & HSV have the same seat bases.
They fit fine & don't impeded with either factory centre console nor B pillar. I retained the original VK seatbelts & mountings. I was looking for original Scheel seats but couldn't afford them along with everything else that was going on with my build at the time.
So, remove the original VK seats with rails from the car & then remove the VK rails from the seats (you are going to reuse these), the drivers side had the adjustable mechanical height mechanism & the passengers was fixed so I required 2 different sizes of box section to obtain the factory VK seat heights (40mm for RHS & 75mm for LHS from memory). When you have the seats out side by side without the rails fitted you will see the difference, measure & order accordingly.
Remove the electrical controls & rails from the VE SS seats, refit the VK rails back into the car, measured & mark the VE seats onto the new spacers (to ensure sufficient leg room & travel on original rails), mark up & drill the holes top & bottom. Bolt (box section) spacers to rails, then in-turn VE seat to the spacers (use all original seat hardware). I had to make up a spacer (2mm) for 1 mounting stud on the VE seat base as it wasn't flush with the other 3 studs. Make sure you check with a certifying engineer for the minimum steel requirements as mine had to be 1.5mm thick (mild steel). Simple really, no welding nor cutting of the original factory items. You need 2 spacers/mountings per seat!
Once completed I found it easier to mount the spacer onto the rails, bolt them into the car, then drop the VE seat onto the new spacer. I've had to take my seats out a couple of times it is about 5 mins work.
There is a replacement plastic RH seat side panel from the std VE Berlina Commodore seat that doesn't have the electrical adjuster switch hole, that can be used instead of the VE SS one (Berlina's have mechanical seat mechanisms).
The only slight issue I encountered, was the original VK seat height adjuster (drivers side) fouls on the VE plastic seat side trim (bottom picture), I just set it at its lowest & it is fine for me.
Good luck.
Measured up using VE rails first, found too hard to fabricate, so went with std VK rails!
Re-trim time.
Factory VK rails with a new VE Berlina plastic side panel on RHS only (passenger wasn't adjustable, so didn't need replacing).
That looks awesome Lacksballs, I'm on the hunt for seats for my VK, it's hard to find even standard VK cerulean seats that people aren't asking a shitload of money for. What did the retrim cost if you don't mind me asking?
