flywheel resurfacing
one_and_only2004
Turbo L98 FTW
Regional NSW Australia
Z Series Thunder Utility - Turbo
i just picked myself up a free lightened solid flywheel + clutch plate + pressure plate from a friend, but they both have had their faces pretty worn to the extent that there's some pretty impressive grooves worked into them.
What sort of places are out there that could do this for me?
hail storm
The fly wheel can be done at any Good Engineering shops.As for the pressure plate,just give it a de-glase with some 180 grit wet & dry sandpaper.
social
Ute Finatic
South Aus
2012 VE Thunder
im also quite interested in how to resurface the flywheel, can it be done by hand with wetsand paper?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
ditch the pressure plate and get a new one and off to the engine builders with the flywheel wont cost much to skim it off if there is enough meat left on it after its been lightened before
Zuicider
Banned
Stonedville
Set of thongs
there is a few ways to redo the face, surface grinding and if the grooves are too deep for your liking get them puffer welded
VT-565
QLD
VT
Machine finish should be fine.
By the way, WTF is 'puffer welding'? is there something i should know?
