I was a dash basher until a week ago when my fuel gauge stopped all together. Since then I have changed the fuel/temp section of the cluster with a new one. Still no joy, could this dry socket issue be my problem? Or when I replaced the fuel / temp gauges did I eliminate this?
No I didn't, I wasn't even aware of this issue before, hence buying a new fuel / temp gauge. Now since I've become aware of the voltage regulator issue the only thing I keep reading about it is, it's the way to fix a "sticky" gauge. Not an inoperative one. So I guess my question is, does the voltage regulator solder connection issue commonly cause the fuel gauge to become completely inoperative?
Well i pulled mine apart again and didnt notice any issues with the solder joints, but i re soldered them again anyway as per instructions on here. I checked the PCB for cracks / damage and no probs there either. Put her back together and no joy......................... So now she has a re soldered voltage regulator and brand new fuel temp gauge!!!! Im wondering where to go now? Is it possible that the issue is on the other end down at the tank???
