apollo13
I replaced a fuel pump. By the way, the "micro-encapsulated bolts" for the fuel tank are no longer available, They just gave me plain cadmium-plated instead.
I rubbed some beeswax on the thread - and it has not leaked.
I put 17 litres in and started it. Fuel guage only showed 1/8 which is too low. I only drove a few km then left vehicle in garage.
Then next time, fuel guage did not move, and I get low fuel light on.
So I thought the float had fallen off the clips. I pulled the thing out again, but float was still attached. examined it under bright light, and see that the wire goes
to the spring around the hinge, which then connects to the wiper. The wiper is still making contact. I checked the plug and there was no dirt in it.
I plugged it in, and turned key to on, and the needle moved. So I put pump and sender back in the tank, tightened the bolts, attached hoses and tried again.
Fuel guage stuck on empty. I checked the guage by connecting a 100 ohm resistor, and it swings to just below half.
So I presume the thing is old and worn, and juggling it back inside the hole disturbed something.
I see on GMH parts catalogue that the sender is not available seperately. You have to get the main assembly with the fuel plumbing. I doubt they would be in stock anyway.
I saw an on-line wrecker selling the whole lot, but it could be from a hoon's car with hard suspension, so that it had a whole lotta shakin going on.
Are these senders repairable?
