funny clutch sound
figjamidhVK8t4
84 VK 3.3 Converted to EFI
ok peoples here goes every now and then when releasing it makes i funny wierd rubbing noise anyone had a similier prob and know what it could be....and before i get asked the clutch cable,bearing,pressure plate are about 4 months old...
cheers
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
Clutch fluid still pumping? maybe something needs grease'n
Sammy
41
Tenambit, NSW.
www.oldholdens.com
LH Torana with Ecotec V6
doesn't the vk use a cable clutch ?
if you rest your foot on the clutch enough till it just takes up does it make a noise then .... has it been making the noise since it was installed or just recently started to make the noise ?
vk3800
42
Coffs Harbour NSW
VX S Series 2
VK's use a cable
SL/ENUT
The SL/E Fanatic!
Burnie, Tasmania
VB SL/E 5L
Throw out bearing cactus?
nizmovk
NZ
VK wagon
rubbing sound is a bit vague.. but could be anything from pedal being too dry, to loose clutch plates. Try to locate where the sound is coming from, inside/outside and go from there.
figjamidhVK8t4
seems to only make noise every so often when i take off releasing clutch i think i might be the cylinder that goes into wall
craigvk
Banned
VK 5L Calais
The old Commos all had a cable driven clutch, not a hydraulic one. When did the hydraulic clutches come in? VN Commos?
