Fun_Bucket
- Mar 23, 2009
- 2,990
- 9
- 0
- Age
- 38
- Location
- Cairns White Rock
- Cruze II sri
A little thing i have been working on for a while now. It's a 2.48 meter Zodiac Fast roller, it's the sports model with the inflatable keel and 2 piece floor. It's the smallest inflatable boat designed to plane.
Factory rated to 8 hp, i will be using a modified 30 hp Tohatsu.
Repair and service wise i have:
- Replaced the top and bottom swivel tubes bushes, thrust plates, and fitted new o-rings.
- Fitted new transom brackets.
- Fitted new tilt tube, and new tube bushings.
- Replaced impellor, top and bottom gaskets, fitted new stainless screws.
- Replaced bearing carrier oil seal.
- Fitted new pan seal, new pan bolts, rubbers, and spacers. Completely
sealed pan section of with sikaflex.
- Replaced power head base gasket
- Remaining power head gaskets are here but not ready to be fitted yet.
Modification wise i have :
- Fitted solid alloy mounts top and bottom.
- Added 4 x 0.75 Inch holes above cav plate for exhaust releif.
- Removed tilt mechanism and shallow drive unit to shed unnesacary weight.
- Fitted PowerTech SRA 10 in 10 P propellor.
Future plans :
- Remove starter ring gear and lighten flywheel
- Fit Boyosen reeds.
- Experiment with different length velocity stacks
Future plans :
