I did flush it properly......to flush it properley you should:
empty it out via the lower radiator hose
fill it up with clean water
start it, let it warm to operating temp
turn it off remove lower hose
repeat 2 or 3 times.
an easier way is to just take the thermostat out and fill up>drain>fill up>drain>fill up>drain.
just running a hose into it isnt flushing properley.
edit* just read the extra posts. LOL! changing the rad??? really?? lol, epic waste of time. if there was tranny fluid in your water it'd be milky white. same as oil.
why the fk didnt you just change the coolant????
