Jeubnoob
- Feb 11, 2016
- 1
- 0
- 0
- Location
- New Zealand
- 2004 V6 VY Acclaim, Series 2 sedan.
Okay so I have trawled the existing posts and can't find an issue quite like mine listed. If there is a similar post feel free to link it!
So this issue started a few months back just on and off but it seems to be getting more pronounced. Basically there is a metallic grating/grinding sound that only happens right on 2000rpm and only when the vehicle is moving. I have occasionally heard the same sounds briefly at around 3000 but no way near as significant. It is also hard to say where the noise is coming from when driving.
I have had a look at the drive shaft and the centre support bearing looks a little worn, but I assume that would be a noise more consistent with vehicle speed rather than engine speed. At the same time I don't think it's an issue with the actual engine as it doesn't make the noise when stationery at all. So I guess the issue is somewhere around the transmission or the connection to the drive shaft. Anyone have any suggestions on what might be the issue?
