hand brake adjustment???
hbdvysute
Utes the word
vy s ute
i got under mycar today to try and adjust my handbrake as it is taken about 15 clicks to tighten where it should be around 7, does anyone know how to do it, icould not find anyadjusters of any sort>>> any help would be greatful
vy_acclaim
Perth, WA
HBD VYII Acclaim
I replaced my handbrake several months back - noted that the cable is only 3- 4 feet long. Should be immediately under your center console.
dave j
33
vl calais turbo
what model commodore is it on
jav360
1970 AMC javelin, S2 stagea
There is a handle adjustment under the boot of the handle, you'll need a deep 10mm socket and wind it down, this tightens the cable to the handle.
Should be around the 6-7 clicks.
If you've tightened the handle and it still doesn't hold then it will require adjusting at the rear handbrake linings inside the rear discs.
Try adjusting the handle first and see how you go.
Dak666
VY Berlina
Other way around, never adjust the cable by the handle first. ALWAYS do the adjusters on the rear discs first.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Second that.
Back the handle adjuster off, adjust the rear shoes, then re adjust the handle.
