Reaper
Tells it like it is.
- Aug 15, 2004
- 6,494
- 11,557
- 113
- Location
- SE Suburbs, Melbourne
- RG Z71 Colorado, 120 Prado , VDJ200, Vantage
rattattack1313 said:Have a goood read of the manual, if you have one........make sure everything is kept clean..........look for a ridge in the top of the bore, if a large ridge is present, it needs a hone-out........make sure all the old gasket is off both surfaces.....and while the head is off, get it checked, make sure it isn't warped.......and look carefully atr where th hasket is blown....has it burnt a lot of metal on the head/block???? hope not...usually this is a prob if you have driven it for ages and ages with it blown............hope this is a little help..... :thumbsup:
All good tips - also, check that the head is not cracked. I'd be suprised it it isn't (even slightly) warped and needs to be machined again. Also, be careful when replacing the coolant. VL's cooling system needs to be bled from the top of the engine - read & follow the proceedure in the shop manual.
You need to find why the gasikit blew so quickly otherwise you will be back here again in a few days & out the $$$ for another gaskit!.
Reaper
