I myself got a Stinger 0-gauge wiring kit for about $150 because some retard went into JB and without asking decided to rip open the case to inspect the content, obviously no-one told the retard its just friggin cable, it doesn't look any different behind a plastic case. Oh well, one mans stupidity is another mans bargain.
i scored a 0 gauge stinger kit and also 2 sets of splits (alpine type x and pioneers best ones) and an alpine usb headunit all for 100 bux from a wreckers
spewing the motor and battery was gone im guessin it would have been an optima yellow top and a high amp alternator
just look around a few places even ebay has 0 gauge kits every now and then for cheap
ok just thought id clear up the info on the subs as he got em off me lol
they are 307d2 (dual 2 ohm per sub) models which have 8 terminals on the box (4 on each side) the middle terminals are bridged under the rubber cover so they are hooked up in series (4ohm each sub so that u hook em up in parallel for a 2ohm monoblock)
really suited to a monoblock into 2 ohms or 2 channel amp with 2 x 400rms into 4 ohm
the reason why they both move is because they have a centre divider baffle (or whatever its called) with a 6 inch hole in it so they are not sealed from each other
any more info needed on the subs let me know
(also kizza could u leave me feedback
thanks )
