help? Clicking noise in left rear wheel hub
ADTR-jolan
Slacks creek
2001 S/c Vx commodore
Hey guys I have noticed a clicking in my left rear wheel hub? It sounds very similar to the cv joints that went bad in my 03 impreza but this clicking noise just started out of know where, thanks guys
mpower
check the obvious things like stuff stuck in tyres and rocks inside wheel covers
dirty hands
ipswich qld
magna
loose wheel nuts / handbrake shoe / rotor or caliper ..who knows
you will have to jack up that side and spin it
check out the cv joint... if it isnt something simple
gm1961
62
Hi All
funny enough last service the car was on a hoist and i turned each wheel the left rear makes a clicking noise
there is a slight buckle in the rim, but it does not touch anywhere, i was short on time as i wanted to go home and it was getting cold , but the initial impression because the noise was always with the tyre valve at about 5ocklock was that its not a CV and there was no play in them, so they think a high spot on the brake rotor or even the hand brake shoe - next tiem it is up the wheels will come of and have a good look
regards
geogre
ADTR-jolan
Slacks creek
So your car has the same issue as mine haha let's help each other solve the same problem hopefully
Immortality
Staff member
Sth Auck, NZ
Stone stuck in the tread?
C.V may feel OK manipulating it by hand but in now way can you simulate the same loads by hand as is applied by the engine. Best bet is to actually remove the C.V and inspect it.
Also, when the car is on a hoist and the suspension is at full droop the load points inside the C.V will be different to when the car is sitting on the road at it's normal ride height.
edit: high spots on rotors or drums tend to make more of a squeak or rubbing type noise rather than a tick from my experience.
