Help identifying flywheel type
ZM1234
VE SV6
Hi guys, had a dragging clutch so have pulled apart clutch assembly to replace necessary components, just need help identifying what flywheel I have as I know you can't reuse the dual-mass ones if they're too far gone.
2007 VE sv6 manual (aisin ay6), 330000km.
Due to the Ks of the car I don't wanna break the bank, but also want it to last another 50-100k km at least.
Concentric cylinder is gone so will replace it, clutch has like .5mm of friction material left so may as well replace while out, just need to know what clutch I need to replace it with. Photos of current clutch are attached
Should I replace this flywheel? What would you reccomend for a clutch kit for this car?
Clutch pressure plate
Exedy clutch disc (I can find this part number online, can't find what flywheel it attaches to)
flywheel
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
Looks like a SMF to me. If it was DMF there should be two separate parts and the part that’s bolted to the crank should be separate to the section that the clutch engages with.
I’d replace the whole lot though as the friction face doesn’t look too crash hot and a new flywheel is probably not that much more expensive than getting the existing one resurfaced.
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
I wouldn't worry about it,it doesn't look that bad,just replace the clutch and pressure plates..If you really want to machine the wheel I think they charge about $150 to $175..
Dylan kingswood
33
Hobart
2011 s2 Ve ss
Single mass and last couple ive had done where $60, all new clutch installs need flywheel machined to retain warranty and all new clutch to bed in
