Help installing 6.5 inch speakers in VT
Helmo645
f
Hey guys :D
So now i'm pretty decided on going with the splits, these sony ones most likely Ryda Car Audio - Sony XSGTX1620S 6" Split Speakers($99.95) and then i will be installing them myself. However as a complete noob at ALL of this im wondering if installing splits by myself is the best idea as they will be even more complicated then just coaxials of the 6inch variety.
Being 6.5inch splits i figure you need to do a bit of chopping into the car or something to fit them? Anyways just how easy would this be for a beginner :p
Lamo
VK SL + LH Torana + VZ Crewman
Depending on the basket size of the speaker, you may have to 'thin' the speaker pod mounting surface a little to squeeze it in. There is no other chopping involved.
Helmo645
f
Ok sweet thanks alot, also to install the splits will i need a soldering iron or anything or can i just like twist the cables together to join them , sorry i have no idea what im talking about
acarmody
Donati..Whoa Green
VX Berlina
Have a look at the crossovers, most every pair I've seen the wires screw down between plates, so just a screwdriver needed. On the speaker end does the supplied wires have spade terminals (slot on)? If so than just slide them on, if not than soldiering may be required.
chooky1980
Donating Member
deniliquin
www.cardomain.com
vh sl/e,vk berlina
should be a straight foward job mate.i put 6.5s in a mates vt and they fit it without modification to the mounting by memory
SuperSixty6
Alto Rullo
Brisbane.
Landcruiser TD
LOL!
I assume you are not amping them, Or upgrading factory wiring?
If you are not upgrading Factory wiring, You may need to solder a few things to locate the Crossover internally (I would not put this in the door).
Cheers.
Super6
