HELP! leaking coolant high from motor
poolzanator
2011 VE sv6 manual ute
Got a leak somewhere high in the motor, where could this be coming from? Not coming from radiator hoses!
tavrin
VS Executive S2 L67
Checked around the waterpump? The gaskets can leak after some time if no gasket maker was used on them... or the waterpump can leak from the bearing
A good way to source the leak would be to use some degreaser and clean the engine up nicely. Then the leak will be really obvious.
Good luck.
vsl67
VS l67 statesman
If you are using the usual green glycol coolant it will glow under a white led torch in the dark and make finding leaks easy
VPRob
nowra, NSW
VP executive sedan V6
inlet manifold is always a likely culprit
two-bit
old enough to mang better
VS S series II
external leak from inlet manifold, thermostat gasket/ housing, water pump, or that little pipe that comes out the side of the water pump there is 2 o rings on that, that fail. get a white light / black light and have a poke around. where on the motor is it? front or back?
VPRob
nowra, NSW
another weak point is the plastic fitting for the by-pass hose above the water pump. There's an identical fitting for a heater hose on the back of the inlet manifold for a heater hose. They can be replaced with brass fittings. The plastic ones usually break up when you try to remove them but they're not too hard to pry out
Pollushon
Boost gives me a bar....
VY SS
Is it a VR (L27) or VS (L36)? Leaking front or rear? Big difference for likely leaks. The L36 doesn't have those crappy plastic manifold adapters that VP rob mentioned.
VPRob
nowra, NSW
I forgot I was on the VR/VS forum (I use VN/VP and VR/VS because my ride is a VP with a VR(6) transplant) but when I look at the original question I see that Poolzanator lists his ride as a VT in which case it's an ecotech (obviously)... unless it's a V8? He doesn't give any other info. Maybe he asked his question in the wrong forum and that's why we haven't had any response. This forum works so well for me because people exchange knowledge- it's a 2-way thing
