In ur opinion guys what is very similar to the twin throttle vn ss group A Manifold.
Is this what i want?
This is a genuine msd 4 barrell 1000cfm throttle body. ideal to convert carby to injection or to run a high rise manifold on your efi holden/ford. comes with throttle position switch and idle air control valve.
Price: $950.00
same as the carby single plane manifold with efi holes drilled in the accomodate injectors. these single plane manifold make best power from 4000-8000rpm. ideally used with a msd 4 barrell throttle body to create the old school muscle look but still retain efi.
Price: $1045.00
WWW.TUFFCARPARTS.COM.AU
Brad,
42lb injectors are way to big for your application these will support up to and slightly abover 400rwkw, the best injector choice u can go is vt ls1 or vx ls1 from 260 to 300+ rwkw.
as for manifold, go with what i spoke to u a while ago, forget alloy manifolds as IAT's go through the roof.
As for the harrop manifold, ive done a few 304's with nothing above 9.5:1 cr, mild head work and running a solid camshaft and they all net around 230rwkw at 6700rpm.
And to others, i will gladly put my hand up, and say ive actually removed one of those walker manifolds, as it made worse power and torque, than the standard banana manifold, and was a manifold nothing more than the factory one cut down, and a top plenium made.
