Help ... Opening boot/trunk of VXS
l0ui3
Commodore VXS
Hello ... hope you can help.
I was opening the boot of my VX this morning using the remote on the car key but for what ever reason, it is just clicking but the boot does not release. I tried using the button in the glove compartment box and it does the same thing. VXS does not have a boot lock where I can insert my keys to manually open the boot.
To make the situation worst, I have an LPG gas tank so I cannot access the bootfrom the back seat.
Pls help ....
Thanks.
Louie
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Try pushing down on the boot at the same time as pressing the button.
Escape-The-Fate
HSV, i just want one
Gold Coast
VE SS, M6
either that or lifting it at the same time u press the button..and if/when u get it open check the locking mechanism and clean any build-up or anything on there and spray it with some silicon spray or wd40..
lout
60
Langwarrin Victoria
isn't there a manual boot release cable near the rhs back seatbelt
lout
60
Langwarrin Victoria
fold down the centre rear seat, inside the opening there is a ring pull. pull it towards the centre of the opening
Ado
Are we there yet?
vsII statesman L67
Cant,he has gas.
l0ui3
Commodore VXS
Thanks for all your reply ...
I tried pushing the boot up and down while pressing the button on the remote key but seems to be not working : -(
There is no manual release for the boot at the back. The release in there is for the fuel.
I went to the mechanic yesterday and even him can't figure out an easy way to do this ...
Any other suggestions would be appreciated.
Thanks again ...
Louie
wrx884
WA's ASR Rep
39
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
This is y im glad i painted my VT rear garnish :p aswell as having it lookin better hahaa.
Can u take out the rear seats and parcel shelf and even take out rear speakers or the metal plates 2 reach the boot realease from inside?
kjparker
VY S1 Acclaim
Does the solenoid make any sound when you press the release button?
If it isnt making any noise, then you might have an electrical fault, check fuses etc.
You may be able to get it to trigger (if this is the problem) by applying 12v to the appropriate place in the loom.... (not that I know where that is!)
Have you spoken to a panel beater? No doubt they would have encountered a problem such as this before
