iank1000
- Dec 18, 2020
- 22
- 2
- 3
- Age
- 74
- Location
- melbourne
- VL berlina
Finally got the inlet manifold off to get at the fittings, both are mild steel badly corroded and leaking.
The rear one I believe is 3/4 bsp thread, so if I cut off the smaller bypass tube on it it looks like a 27mm socket will fit it, that one has a pin hole corrosion in it
The front one is in really bad shape, failed completely and is pressed into the block, so doesn't look easy to get out and replace.
If anyone has done the front one would really appreciate their help.
If anyone knows where the fittings can be bought at a sensible price please advise. A pic of each one attached.
