Charg'd
Now i got your attention, just wondering how id go removing the snorkel from the airbox in my vt xu6 so i can paint it, its got a kinda star shaped head on it, any help appreciated, thanx in advance
Do you mean the 2 screws in front of the snorkel opening? Unless the VT XU6 is different to a VT S then mine just has phillips head screws which simply screw out with a regular PH screw driver then you simply prise out the push in plastic bung thingy that expands when the screw is tightnened and the snorkel breaks away from the airbox easily.Charg'd_VT_Xu6 said:removing the snorkel from the airbox in my vt xu6
mines the same... regular ph driver does the trickSUPERV6 said:Do you mean the 2 screws in front of the snorkel opening? Unless the VT XU6 is different to a VT S then mine just has phillips head screws which simply screw out with a regular PH screw driver then you simply prise out the push in plastic bung thingy that expands when the screw is tightnened and the snorkel breaks away from the airbox easily.
