I wouldn't be calling people smartass's just yet.......
YouTube - taking the rearmount turbo vp 5l for a quick spin ......turbo and screamer is loud in cabin
The noise is not an issue, Its just something stupid to do to a car we have lying around. Lag wouldn't be an issue either, If we were worried about lag, we wouldn't even bother with a turbo.
I still don't see how a Intercooler would heat up to an inoperable temperature. Thermos on the cooler with a cold air intake to the thermos would do the job easy.
In all seriousness, it will be funny having a turbo that will barley spool and hit boost at redline. If the car was meant to be anything serious, we wouldn't be going for a rear mount. The screamer will also be external from some part of the frame for mega loudness. I like doing funny things.
He's been helping me with my rear mount, Only reason his setup works is the way its run & the vents, He has no backseat an the boot is totally stripped an vented...
He also has a TT355 thats an absolute beast.
And you do know you can make serious rearmount turbo kits yes?
With the correct housing sizes, as STS has been doing it for quite a few years, Mainly on camaro's in the states & mustangs which have minimal engine bay room.
EG:
Perfect 5ltr single turbo setup is a gt35r with a .70 intake & .82 exhaust like my setup.
With the lower exhaust temps it should spool at 2.7k`rpm & be efficient to 5400rpm
And rearmounts + screamers are not loud just so you know...
Sreamers are only loud when mounted inderect of an engine bay before a muffler of some sort. Screamer is just a non plumbed back wastegate,
Now you WILL NEED
39-42lb injectors
Scavenge Pump
Turbo of some sort for your application
2bar map sensor
and a few other bits an pieces which are pretty self explanatory.
MaT
EDIT:
After all this talk I'm quite worried about what you will end up doing to this grange with an inefficient turbo setup.
