HIGH HP DRIVELINE PARTS
VE SS N2O
Sussex Inlet
VE SS Ute
also is it for drags or track work needs different strengths/weights to best suit
Hi,
It is mainly for drags, but also may do some roll racing - definitely not circuit/corners.
Thanks Rob.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Might want to think about using an LSA diff and cradle set up for your rear end.
  • Like
Reactions: Lex
Woodsy104
24
Perth, Western Australia
2007 VE Commodore SSV Sedan
Hi,
900 engine HP and it is an Automatic, using the 6L80e transmission.
Thanks Rob.
At minimum I would get a fully built 6l80e and a truetrac diff. I suggest just build the whole drive train as it will find a weak spot and you will start breaking parts (axles, driveshafts, etc)
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
If l was going to replace, l'd go the 6l90. Supposed to take more hp?
Woodsy104
24
What cars (toy trucks, not real trucks) did they come out on, ;) in Australia?
they only came in American models of SUV' and "trucks". But plenty of performance shops sell them for around 5-6k.
  • Like
Reactions: Lex
Pollushon
Boost gives me a bar....
VY SS
Your trans will be the weak point and how far you go with the rest depends on the power you plan to output
VE SS N2O
Sussex Inlet
VE SS Ute
I have had a 6L80e built and I have a warranty in writing for up to 900HP - yes using a Truetrac and 3.45 gears
