High Pitch squeal
Phoenix21
Donating Member
Crime bourne, Vic :P
93 VR, 95 Statesman, 2003 VY SS
hey all
i changed my thermotstat yesterday and i just keep running into problem first was the injectors rails, anyways i started upto day after i got every thing back together and now it making a rally high pitch squeal any ideas any help would be great its anoying the hell out of me thanks matt
Swift
VY Clubsport
Is it your power steering? or is it a squeal coming from the ECU?
pandaman
Aussie Muscle Fan
35
VN Berlina 5.0 A4
Does it change volume or pitch with engine speed?
pandaman
Aussie Muscle Fan
35
VN Berlina 5.0 A4
if it's obviously related to engine speed it could easily be something rotational like a bearing thats being a bastard, I used to have an alternator with a dodgy bearing that shrieked like a banshee above 3000rpm, great fun. It's also possible that it could be a very small leak somewhere around the throttle body and the air rushing past the hole is causing a whistling sound. You might want to check that the hose clamps holding the rubber hose onto the throttle body are firmly tightened and there are no obvious holes in the pipe. Other than that just listen carefully and see if you can isolate the noise further.
