I find it odd that some cars seem to get no difference between std unleaded and the higher octane fuels, sure conventional PULP over std unleaded would be unlikely to do what 98 does but at least it should make for a smoother running engine with some other benefits, given that the engine is running properly in the first place.
My calais being still fairly new shows no massive power increase "and I have no desire to wring it's guts out on any dyno to test the actual power", but fuel consumption is at least 10% better over a full tank and it does run smoother, so the added initial fuel cost is not a problem.
However, the old VS wagon I gave the daughter last year has shown a huge difference in everything, town fuel consumption dropped a good 20%, highway means an easy 700 k per tank, but that engine never went under 450 k per tank on std fuel when driven hard. BTW At those times I saw others that were lucky to get 300 k driving easy so it would be fair to say some cars needed a good tune up or the drivers needed revised driving habits.
Up here it's sometimes like being lost in the desert as we would have to drive 40k to buy PULP as it was not sold in town, with the BP going Caltex and offering all three fuels it made buying it a tad simpler.
On the cars here that have shown no increase there is possibly three things, the fuels were mixed together, they needed some work done on them or it's very possible in these days of high prices they are buying fuel that is not exactly true to the label, it does happen, others here (also commodores) that have changed over have found substantial differences so it's not just me, the fuel is very different.
I did mention that mixing std unleaded and PULP is not the thing to do, (Ask the fuel company if in doubt), they are different fuels that do not mix properly and should not be mixed into anything more than a near empty tank, in practice it would be ideal if the tank was drained first before changing fuels, and buying your fuel at the same place (a bit like I have to) and doing it all the time if possible would be preferred.
The difference to the std unleaded and PULP that was sold out of town was at least a good 10% but the Vortex now sold here is vastly different again and does way more than what a new set of plugs might do, and why I wondered if anyone else saw the improvement, obviously some do, as for the rest there must be other variables in play, it would be impossible to see no difference...
For the doubters or just curious, my boat carried 800 lit of fuel under deck, at 5600 rpm it used 5.2 lit per mile (for both engines), (think on that figure for a sec) so the difference between using std unleaded and the PULP meant nearly "200" lit less fuel per trip, at the exact same revs, it ran much smoother, would start quicker and had noticeably more power, so the differences are not just an odd litre or two, but in that case 25% less, go figure ? engines are engines be it on water or not.
