Holden Caprice BCM issue??
Hzk02
22
Bahrain
2004 Holden Caprice
I have a 2004 Holden Commodore (Caprice 5.7L) Statesman, was switching on the car one day and suddenly the indicators stuck on, horn blaring stuck on, windshield wiper stuck on. I changed my BCM to an Exact used one programmed it then 2 days later happened with the other BCM. What could be my issue? Thank you.
BlackVXGTS
Melbourne, SE
Did you have your car scanned for error codes?
lout
60
Langwarrin Victoria
sounds like a short in the upper steering column area
now for 20 questions
what havent you told us
flood car?
just fitted accessories?
Hzk02
22
Bahrain
2004 Holden Caprice
Car is bone stock, bought it new never flooded.
flood car?
the_boozer
no more VK
51
Shitsville Morwell
hilux
something wrong with the clockspring is where Id start looking if the srs light is on the must be srs codes?
Fu Manchu
WA.
Was also about to say faulty clock spring.
And now I have as well.
Fu Manchu
WA.
Common Earth?
VT2Commie
WA
VT2 Clubsport R8
Common Earth?
Think your on to it @Fu Manchu , X157 ground bus bar, the one just in behind the battery bolted to the side of the engine bay. It has about 4-5 earths in a plug which is plugged into an earth strap and the earth strap is bolted to the body. Notorious earth for faults like this.
It is the main earthing point for all the issues the OP is having.
Clean this earth point and ALL the earth connections to it and get back to us.
