Holden ve radiator cap
johnni
35
Ve Commodore
Hey all,
It's time to replace my radiator cap on my 2008 ve v6 as it's starting to leak.
Atm I have a cap which has a 125kpa/18 psi raring on it and I've looked online, I can buy the same or a 140kpa/20psi.
Is there a big difference between the two? As if I buy the same cap, im sure it shouldn't cause any issues?
Thanks all
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
johnni
35
Ve Commodore
Fu Manchu
WA.
Get genuine. The 140kPa cap is the updated cap. Used VE-VF. I use it on my VZ as well.
J_D 2.0
Ipswich
I've been using a aftermarket repco radiator cap for the last 5 plus years without any issues but now it's leaking.
I can go get the same or go genuine like the link?
Realistically about 5 years is the usable service life of VE radiator caps just based on the design of them. The only thing sealing it is o ring pressure on the sidewall of the filler neck. Once the o rings compress and get flattened with age it will leak.
If you’ve gotten 5 years out of the Repco one then getting the same again would probably be ok but if you’ve still got an ex-Holden dealer in your area you should be able to swing by and pick up a genuine one from them.
