Horn wont work
Red
Horsham
96 VS Commodore
The horn on the VS will only work when the steering wheel is turned? When the steering wheel is in normal position (straight) it doesn’t work.
gtrboyy
vt ss & lc gtr
Brass button underneath steering horn ring worn?????
losh1971
North Tas
VE Series I SS Ute
x2 this seems to be the most common reason the horn doesn't work.
Red
Horsham
96 VS Commodore
I will have a look in the morning a check it out. I obviously have to take the steering wheel off?
losh1971
North Tas
VE Series I SS Ute
Yes the wheel has to come off.
Red
Horsham
96 VS Commodore
Put some solder on the brass button and it is working again. It was worn and not contacting when the steering wheel was straight. Couldnt get steering wheel off so i undone the column covers and went in from there.
