Jasminka
- Jan 31, 2014
- 49
- 12
- 8
- Location
- Mandurah
- Cerise Caprice
The old VS is just used a shopping cart nowadays. After warming up in the morning, the temperature gauge goes 3 marks above normal, then quickly settles back to normal.
On return trip it does not, but the motor hasn't cooled down fully. I was told this is caused by air in the system. I have bled it twice: first by removing the radiator cap with nose uphill and topping up as the coolant went down, then next day used the bleed screw, but this blip still happens.
So other possibility would be thermostat? It had overhaul last year - the thermostat, radiator cap, sender and heater valve were all replaced. Radiator and pump were replaced 2 years ago.
