Sean880
- May 14, 2009
- 1,191
- 193
- 63
- Location
- VIC / NSW
- 2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
1. A 10 inch wheel in 48 offset with a 285 tyre will definitely rub the rear guards and you will have to roll the rear guard lips for clearance.
2. To clear the rear guards as they are now you were correct the first time with 54 offset. Actually anything from 53p to 57p offset will be fine with the 285 tyre for decent clearance on each side of the tyre and no guard rolling. If you were not lowering the car you could get away with 50p and no guard rolling with the 285 tyre but I would definitely go for a little higher offset if you intend lowering the suspension.
3. Once the car is lowered, if you get any rubbing with that 285 tyre and high wheel offset, it will be from contact with the bumper bracket that sits just inside the rear guard. If a tyre touches the bracket with enough suspension movement once the new package is fitted and the suspension is lowered you will have to modify the bracket or grind it down so it clears the tyre.
4. I would go for a higher offset wheel as you propose so the 285 tyres clear the rear guards as they are now and you avoid guard rolling.
So..........
- 285 rear tyre
- no guard rolling
- 10 inch rear wheel, offset 53 - 57p
- lowered suspension
- check for contact with rear bumper bracket when fitted.
So..........
- 285 rear tyre
- no guard rolling
