i would like to get a truck horn as an added horn apart from stock one.
where abouts can i get it? and how would i go about installing it?
just for a bit of fun.
ah cheers mate, good idea actually.
its probably illegal to have a horn that big in a sedan, but you could do so many funny things with it.
anyone else no how and where? or how much?
yeah, im thinking i gotta get a compressor for the air. then get a string from the roof that looks like nothng, then wen you pull it, it releases the air and bang.
You will need a compressor and an air tank so it will sound. It needs a bit of pressure to work effectively. If the tank isn't big enough you will only get a short burst then you would have to wait til it built up pressure again.
Problem: Most trucks are 24v and have a pretty big compressor behind their horns.
Solution Bias Boating sell boat horns which are 12v powered and do not require a compressore which will be just as loud.
just becareful with it bruv, incase you cause an elderly driver to have a heart attack or soething like that, but hey if you get aorund to it, could you please write up a how-to, with pictures preferably lolll sounds like a laugh to have
