Brysha89
- Dec 9, 2018
- 329
- 45
- 28
- Age
- 34
- Location
- Melton,Victoria
- WM Statesman L98 6.0ltr
Hello everyone i have a WM Statesman l98 its got a couple of leaks put it over a vehicle inspection as i just brought it to work on and was only told has a few oil leaks so i want to clean the engine down and find out where they are coming from. I know i can de-grease it and wipe it but a bit time consuming to do that so i was wondering if its safe enough to use a low powered pressure washer with the electrics over the engine one thing i should mention it is duel fuel and the gas converter apparently leeks so would it wreck that if water spray or de-greaser spray got in it? obviously i would not put the pressure washer nozzle too close to the engine but can i do it at all?
